Old 4-May-2013, 6:29 AM   #7
Tv antenna rotating with a antenna rotator Is Not channel surfing friendly , must wait for antenna to rotate and there Will Be Domestic Situations about the direction the antenna is aimed - Chicago or Milwaukee.
I recommend start with the HD7084P antenna aimed at Chicago at about 154 degree magnetic compass direction.
Some of the Milwaukee Tv stations will be received - through/at - the back angle of the HD7084P antenna that is aimed at Chicago.
______________________________________________________________
As time goes by and you decide that many Tv stations of both directions are required - Chicago and Milwaukee.
Then install a Second Antenna System that is the same setup as the first antenna system.
One antenna system is aimed at Chicago and the other antenna system is aimed at Milwaukee.
The 2 SEPARATE Antenna Systems -->Will Not<-- be connected together on to one coax.
The Separate antenna systems Will Be Separate All The Way to the Tv locations.
At each Tv location a Remote control A/B antenna switch is connected to the Separate antenna systems. http://www.mcmelectronics.com , #32-4425 .
Remote control A/B antenna switching Is Channel Surfing Friendly , press the button on the hand held remote control , Change Antennas And Keep on Channel Surfing.
Concerning inital antenna aiming of one antenna at Chicago or Milwaukee.
Most Digital Tv's have a signal strength meter and some digital Tv's also have a signal quality meter.
The tvfool radar report shows the Chicago Digital Tv stations are all in a group the same direction.
The tvfool radar report shows that the Milwaukee Digital Tv stations are all in a group the same direction.
Being that the Tv stations are all in a group , then adjust the antenna aim to get the most amount of Tv stations down the tvfool channel list ~ weaker signal strength Tv stations , you will not be able to get them all , all the way to the bottom of the channel list --> and that is Ok.
A antenna rotator will most likely not be required for reception of Chicago or Milwaukee because the Tv stations of those 2 directions are in close groups.
________
However , If you like.
________
GUM will have a recommendation for a antenna rotator for the Big HD7084P antenna , and you can tweek the antenna aim when ever you like.
And that is Ok.
___________
You are now aware of the +'s and -'s of antenna rotator and no antenna rotator.
