The tvfool radar plot and channel list you have provide is not showing any antenna height feet above ground.
Do not delete the radar plot and channel list that is not showing any antenna height above ground.
To see if signal strength improves at higher antenna heights.
Make 3 more tvfool radar plots / channel lists at.
10 feet above ground.
25 feet above ground.
40 feet above ground.
________________________________________________
YES - the first 8 Tv stations will be received of the group of Digital Tv stations/channels at 46 degree magnetic compass direction.
And Yes a Large antenna will be required.
