Old 29-Apr-2013, 8:23 PM   #5
If you are going to choose to mount in the attic, measure carefully and use the largest antenna that will fit while allowing you to adjust the aim. I like the Winegard HD769X series for conditions such as yours. However, the Winegard antennas are very challenging to re-fold if you need to remove them from the attic. For an attic install, consider the Antennacraft HBU-44 and HBU-55.
Many folks seem to have the mistaken notion that an amplifier can improve the performance of an antenna. The reality is that amplifiers can not 'pull' a signal from the coax, antenna or air. Amplifiers can only 'push' signal through the losses connected to their output, and to a limited degree they may help overcome some to the noise generated inside a tuner. In your case, the signal levels are not extreme, so a good quality distribution amplifier would not be at risk of overloading. (An overloaded amplifier would make reception worse, not better.) Having said all that, I would try the install with no amplifier, just a passive splitter with output ports equal to the number of connected TVs.
While installing the antenna, make your initial reception check and aim adjustment with no amplifier or splitter connected, just a single cable from the antenna to one TV. To minimize cable losses, use the shortest practical cable to perform this test, you're focusing your testing and adjustments on antenna performance so you want to exclude as many other variables as you can. Once you know that the antenna is aimed well and is able to drive one TV, add the splitter and remaining TVs to the system. At this point, you'll know if an amplifier is needed or not. If all TVs are able to get reliable reception, save your money... However, if you've proven good signal at the antenna, but loose reliable reception after adding the loss of a splitter and additional coax, a Channel Master CM-3410 distribution amplifier is a good choice between the antenna and splitter.
