Knowlegable installer Pittsburgh/Glassport area
Hi,
Knowlegable installer Pittsburgh/Glassport PA. area
I already have the antenna installed on top of my roof. I am having issues with signal drop on 5 channels. I believe there is an problem with the installation, possible loose connection on the rg6 coaxial cable connector, Just needs tightened (I hope).
I also have a preamplifier that needs to be mounted on the antenna.
Thank you,
Dan
Reason: added info
