Old 27-Apr-2013, 6:26 PM   #9
Originally Posted by al bundy View Post
OK, I got a DB4E and a Y10-7-13 antenna. Does it matter which ones on top?
Also how far apart should they be? Im planning on using a single mast either 10 or 20' tall attached to the chimney. Will have to have it tied down good to keep it stable from the occasional tornado that whips through.
Not critical, but conventionally the UHF antenna (DB4e) goes at the top. It sounds like 4' of separation should be easy to achieve... (3' min.)
At 20' you'll need guy wires for sure. I would favor guy wires on each 10' section of mast. http://www.3starinc.com/adjustable_3...enna_mast.html
