UHF only antennas do not block any and all VHF signal... But they simply don't do a good job of reliable VHF reception either. The symptoms you've described are quite typical of trying to use a UHF only antenna in a UHF+VHF market.
Try the VHF add-on kit from Antennas Direct, or if you prefer, you can use an Antennacraft Y5713 (with this option you'll need to provide a UHF/VHF combiner also). Regardless of which you choose, reception of real CH-7,9&11 would be more reliable.
