RonPro, thanks for your patience, address look-up has been experiencing intermittent errors. I've converted your address into a TV Fool reception report.
With the correct antenna, installed free from obstructions such as trees or nearby buildings, you should be able to receive the major networks (ABC, CBS, Fox, NBC & PBS) reliably. MyN should be within reach also.
I would suggest using a Winegard HD7698P pointed at about 200°. An Antennas Direct PA-18 preamp would be a good choice if you are going to have more than 20' of coax or will split to multiple TVs.
