Old 26-Apr-2013, 10:58 PM   #2
To combine the V4 into an existing antenna system, use a HLSJ. http://www.solidsignal.com/pview.asp...-%28zhlsj-1%29
I'd expect the AD V4 to do quite well as an FM antenna. I'd simply use a conventional TV signal splitter. There's no reason to filter the output to the FM tuner... Any decent FM tuner will have plenty of selectivity, ability to reject TV broadcast frequencies. Connect the FM receiver the same way you connect the TVs.
