Well, if it works, it works! I see I missed Ch 4, which I am not sure the 7696 tunes for you. Which may not matter as you have a Fox channel already; a benefit of being in a decent market.
Would you be able to share a few of your signal strength #'s for various channels? Like the best, worst, PBS-56, etc. I am always curious on the results details.
As for the splits, get the right splitter based on the outputs needed. Cap any that are unused. Then compare your signal strengths again and see if you still get what you got. If not, you may have to add an amp between splitter and antenna.
