Pile on...
There is more to reliable reception than raw signal power. Making a signal loud, does not mean it's worth listening to... How much of the lyrics can you understand coming from the car next to you at the light... the one with the rattling fenders due to the over-amplified bass?
Reliable reception starts (and often fails) at the antenna, it's selection and placement.
Another analogy, a hole in the ground with a bit of muddy water at the bottom might be called a well by some folks, but no matter what size pump you put in line... you'll only get high pressure mud at the tap.
