The C2V with indoor base and stand is my favorite "indoor" antenna, however, it's rather large for many folks. You could try the Micron-R, but it may not pick up channels 11 & 13 well enough.
Your problem with the reception of WBFF is due to what I described earlier, not signal power.
I would NOT recommend the second antenna you proposed, one of the "Lava" branded items, as it has an amplifier.
