The signal is strong but it is distorted by something in the signal path that's causing an undesirable reflection.
First, exhaust all possibilities as to the location of the antenna. If that doesn't work out, select a small antenna that's more directional (one with a reflector screen for UHF, for example) and try again.
Do not use any amplifiers.
