Thread: maximum signal
Old 24-Apr-2013, 1:53 PM   #1
dwbsr
maximum signal
Hi,
I have a Channel Master 4228HD 8-bay HDTV High VHF/UHF TV Antenna http://www.amazon.com/Channel-Master.../dp/B000FVVKQM professionally installed on my roof with about 60 foot RG6 cable to TV.
Picking up these stations
Stations
http://www.tvfool.com/?option=com_wr...1ddaa55593ba7b I am just looking for the stations at the
My issue is, low signal strength, fade out and pixelization. I added a RCA TVPRAMP1R Outdoor Antenna Preamplifier with UHF: 22 dB gain, http://www.amazon.com/dp/B003P92D9Y/...410_item_image. Which increased the signal strength 20-40% (depending on channel) and eliminated the fade out and pixelization. The channels when from 40-50% to 55-80%. But I would like to get the maximum amount of signal strength possible.
Would adding another RCA TVPRAMP1R Outdoor Antenna Preamplifier in conjunction with the first one achieve my goal?
Thank you for your feed back
Dan
Last edited by GroundUrMast; 24-Apr-2013 at 4:45 PM. Reason: Converted Antennaweb report to a full TVFR link / protecting OP's privacy
dwbsr is offline   Reply With Quote
