Old 24-Apr-2013, 6:55 AM   #2
I predict there will be No Reliable Reception of Any Tv stations/channels with the Tv antenna in the attic.
I predict that a antenna system amplifier Will Not Provide reliable reception with a Tv antenna in the attic.
I know for a Fact that a metal roof Will Block Tv Reception with the Tv antenna in the attic.
The Tv stations are 54 Plus + miles distant.
The tvfool channel list is showing , 2 Edge Path = hills and mountains obstructions.
The signal strengths are Very Low signal strengths at , 13.0 , 15.1 , 17.5 , 18.1 , 18.9 , NM(dB) in the , Yellow and Red reception zones.
________________________________________
To have a Shot at Reliable Reception of the Digital Broadcast Tv stations/channels to the , north west , at 316 and 317 degree magnetic compass direction.
Remove the antenna from the attic or buy a Winegard HD7696P antenna (and yes I am doing my best to keep the antenna small) (I actually recommend a HD7698P antenna).
And install the antenna that ->Was<- in the attic or the HD7696P / HD7698P antenna , Above the Peak of the Roof in such a manner that reception is not blocked by the roof or cabin in the direction of about , 316/317 degree magnetic compass direction.
http://www.ronard.com/909911.html , install the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , install the #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
http://www.solidsignal.com.
http://www.wingarddirect.com.
http://www.amazon.com.
Try reception without and with a Winegard 'Boost' LNA-100 amplifier.
The LNA-100 is not water resistant , so the amplifier needs to out of the weather.
_________________________________________________
The Digital Broadcast Tv stations you are reaching out for are.
KQDS , FOX.
WDIO , ABC and MeTv.
WDSE , PBS and PBS Repeats and Create and Minnesota Channel.
KBJR , NBC and MyNetwork.
KDLH , CBS and CW.
I predict that some or all of the listed Tv stations will be Reliably Received.
I suspect that all of the listed Tv stations will be Reliably Received.
