Old 23-Apr-2013, 7:45 PM   #4
A Simple 2 antenna reception situation.
A Tv Antenna Rotator ->Is Not Required<- with this 2 antenna set up.
____________________________________________
For reception of the Current +Pending Applications Included Digital Broadcast Tv stations/channels in the Green and Yellow and Red , reception zones , down to and including WBIU the CW and This Tv.
Install a Winegard YA1713 VHF high band channels 7 thru 13 antenna aimed at about 305 degree magnetic compass direction.
Install a Antennas Direct , ClearStream 4 , UHF band channels 14 thru 51 Antenna aimed at about 310 degree magnetic compass direction.
As always , the starting antenna aim direction is the -> starting antenna aim direction.
The antenna aim direction can be adjusted to provide the best reception.
Most Digital Tv's have a signal strength meter and some digital Tv's have a signal quality meter.
___________________________________________________________
---->> Remove the Reflector Screens from the CS4 Antenna.<<----
-->With the Reflector Screens Removed , the CS4 antenna UHF Reception Loops will receive the UHF channels Tv stations to the , north west , west , south east. <<--
With the YA1713 antenna aimed at about 305 degree magnetic compass direction , the YA1713 VHF high band antenna will receive the , Weak signal strength WILL-TV Real VHF channel 09 PBS.
And the Much Stronger Signal Strength , WTHI , Real VHF channel 10 - CBS and FOX and MyNetwork , will be received through/at the back angle of the YA1713 antenna.
Connect the YA1713 and the CS4 together with a UHF/VHF antenna Combiner.
A Antennas Direct , EU385CF-1s , antennas combiner.
The YA1713 is connected to the VHF connection of the combiner.
The CS4 is connected to the UHF connection of the combiner.
The remaining connection of the combiner goes to the Tv/s.
For 1 Tv connected use No splitter , No antenna system amplifier.
For 2 Tv's connected use a simple common 2 way splitter , No antenna system amplifier.
For 3 Tv's connected use a simple common 3 way splitter. No antenna system amplifier.
The Current Tv stations/channels being transmitted and received in the USA and Canada and Mexico border Tv stations are.
VHF low band Tv channels 2 thru 6.
UHF band channels 14 thru 51.
The Tv fool channel list shows the Real Channels that are transmitted and received , and (virt.) virtual numbers.
Your location does not have any receivable Real VHF low band channels.
That is why a YA1713 VHF high band antenna and CS4 UHF band antenna is used.
