Old 23-Apr-2013, 5:50 PM   #1
Chris05
Ant upgrade advice
Hi,
I originally posted a year ago and want to try upgrading antenna.
Currently antenna is pointed at 100 deg and I can get Fox 21.1 fine at nite,
but since warmer weather Cbs 3.1, Nbc 6.1 are not to found.
I also get 13.1 and 31.1 consistently.
I am strongly considering the AntennaCraft Hbu44, but have seen many comparions of it to Winegard Hd7694P. They are both in same price range.
Preamp considerations:
Will new ant need one?
If so, can I use my old CM Spartan 3?
Or what new preamp is recommended for either of above antennas?
Here is tv signal analysis:
http://www.tvfool.com/?option=com_wr...0b86cd0ab2dfdc
equipment:
tower: 20 ft main, with a 20 ft crankup section and 10ft mast on top.
antenna, I believe to be Antennacraft CCS1233 vhf/uhf model.
cable: less than 100 ft from ant to amp.
amp:CM spartan 3, with 2 way split downstream of amp.
Tv: Panasonic lcd with digital tuner and CM Ota DVR.
Chris05 is offline   Reply With Quote
