Old 23-Apr-2013, 2:24 PM   #7
Decivox
Originally Posted by teleview View Post
Indoor/inbuilding and attic Is/Are Not a Tv reception friendly environment and Never Will Be a reception friendly environment.
The building construction is.
Multi-path/reflecting-tv signals bouncing all around -> not good for Tv reception.
Absorbing -> not good for Tv reception.
Blocking -> not good for Tv reception.
________________________________________________
For better reception of the , North/North East Group , of Digital Broadcast Tv stations/channels.
CBOFT , French language tv channel.
CBOT , CBC.
CIII , GTN.
CJOH , CTV.
CIVO , TQ.
CICO , TVO.
CHOT , TVA French.
CHGS , French Tv.
Install a Winegard FVHD30 antenna in/at the North East , Window.
Aimed at about 349 degree magnetic compass direction.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
And run a coax to the Tv location.
The Digital Tv reception of the North East Group of Digital Tv stations/channels are Strong Signal Strength.
Do Not install any type or kind of antenna system amplifier.
A antenna system amplifier will Over Load and be the cause of bad or no reception of some channels.
For better reception of the South East Group , of Digital Broadcast Tv stations/channels.
CHRO , CTV 2.
CHCH , IND. and Movies.
CITS , Religion.
CJMT , OMNI 2.
CFMT , OMNI 1.
CITY , CITY.
Install a Winegard FVHD30 in/at the balcony window or out on the balcony.
Aim the FVHD30 antenna at about 149 degree magnetic compass direction.
The Digital Tv reception of the South East Group of Digital Broadcast Tv stations/channels are Strong Signal Strength.
A antenna system amplifier will over load and be the cause of bad or no reception of some channels.
At the Tv location , a A/B Remote control antenna switch will be connected to the 2 Separate antenna coaxes.
The Remote control A/B antenna switch will change from one antenna to the other antenna.
Do Not try and eliminate the A/B antenna switch.
Do Not connect both antennas on to one coax at the same time.
Both antennas on the same coax at the same time will produce Bad Reception.
The 2 antennas will cross talk and reception will be much worse.
Here is a Remote control A/B antenna switch.
http://www.mcmelectronics.com , #32-4425.
http://www.saveandreplay.com , has the same Remote control A/B antenna switch.
_______________________________________________________
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.amazon.ca.
______
http://www.solidsignal.com.
http://www.amazon.com.
For this 2 Separate antennas with a A/B antenna switch to work , the Digital Tv must have the , Channel/Rescan/Scan/Add Feature that makes it possible to put more channels into the tuners memory with out erasing the first channels that are scaned into memory.
Some Digital Tv's - Do Not.
A note , CRC-DT-channels 46 , 1-2-3-4 , and , CRC-DT-1 channel 51 , are Test channels , used for testing Digital Broadcast Tv transmission and reception systems.
Wow, very informative. Thanks!
Too bad the FV-HD30 has a 2-4 week lead time from Amazon.ca
Decivox is offline   Reply With Quote
