TV Fool report link
http://www.tvfool.com/?option=com_wr...1dda3033f3e8ef
Live in east central Illinois. Report shows the broadcast stations I am primarily interested are 3.1, 15.1, and 27.1. Also 2.1. 38.1, and 10.1. If I am understanding the readout, these towers are approximately 180 degrees apart. Some at 147 and the others at approximately 310. I have been considering either the Mohu Sky or the Db8e. I plan on mounting the antenna above my roof line (approx. 25 ft.) on a mast that can be rotated from the ground. I will be using RG6 cable for all runs. I would like to be able to split the signal for two televisions. To the southwest of my residence (approx. 1/4 mile) is a large Cargil Grain bin operation. I can however receive ch. 2.1 and 38.1 consistently with a cheaper amplified RCA antenna. These channels are at the 147 deg. direction. Needing advice or opinion on which one to purchase. Thanks for the help.
