Old 23-Apr-2013, 1:53 AM   #7
For reception of the -->Easier To Receive Michigan , Local Digital Broadcast Tv stations/channels.
WCMW-DT REAL UHF Digital channel 21 , virtual number (21.1-2-3) PBS channels.
WWTV REAL VHF Digital channel 9 , virtual number (9.1-2) CBS and Fox.
WPBN-TV REAL UHF Digital channel 50 , virtual number (x) NBC and ABC.
WFQX-TV REAL UHF Digital channel 32 , virtual number (33.1) Fox.
Install a Winegard HD7696P antenna with a Winegard HDP-269 preamp.
Aim the HD7696P antenna at about 70 degree magnetic compass direction.
A antenna rotator Is Not Required to receive the above listed Local Michigan Digital Broadcast Tv stations/channels.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
__________________________
http://www.ronard.com/909911.html , use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , use the #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
_______________________________________
http://www.solidsignal.com.
http://www.amazon.com.
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path/reflecting , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best practice to install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception , (north east , east , south east) , including your own roof and house.
The Tv's Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through trhe Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
