Tv Reception
DKBTZ 24 is by Butte. I recommend the Antennas Direct XG 91 to pick up that channel. Tip the antenna up in the front so the length of the antenna is more in line with the tv transmission that is being diffracted across the tops of the hills between you and the transmitter. Diffraction makes the tv transmission to bend a little downward.
