Ok, I'm going to go with the DB4e and most likely the Winegard YA1713. I keep reading your name and it makes me think of a question, I was most likely going to "ground" the cable with a grounding rod just before it goes into the house, is that sufficient or do I need to be running a grounding wire straight from the mast to a grounding rod?
Thanks,
Drew
