I was actually talking about the DB8 not the DB8e, the DB8 is about $100 cheaper. What are your thoughts on the DB8? So if I choose to use one antenna system, is there a certain distance the VHF antenna should be from the UHF antenna? and should the VHF antenna be above the UHF antenna when mounting? Also, the pre-amp should be connected after the combiner correct?
Thanks again for everything its much appreciated.
Thanks,
Drew
