Old 21-Apr-2013, 7:31 PM   #4
Take a close look at the the documentation for each antenna...
http://www.antennasdirect.com/cmss_f...s/DB8E-TDS.pdf
http://www.antennasdirect.com/cmss_f...s/DB4E-TDS.pdf
When the elements of the DB8e are set 30° off broadside you get remarkably similar gain compared to the DB4e. I don't see how the $200 DB8e brings value to this specific application when compared to the $60 DB4e (Amazon).
If the buildings are a source of multipath, you may find yourself forced to use two dedicated antenna systems or a rotator. However, that brings me back to the point that the DB4e and H-VHF combination is a solid solution for use as one of the two antenna systems if you prove that you have to go that route.
