Old 21-Apr-2013, 6:57 PM   #3
AGF79
If I was to aim the DB4e in-between the local and Detroit channel I would be aiming directly into the center of downtown Toledo which leaves me with a whole lot of tall buildings to contend with. What would you think if I was to use the Antennas direct DB8 for that?, since each side of that antenna is movable an then still use a hi-band VHF antenna aimed at Detroit?
Thank you,
Drew
AGF79 is offline   Reply With Quote
