Just because a antenna is a number one seller does not mean that the antenna is the correct antenna for every reception situation.
The ANT751 Will Work for - Your reception situation - ->the degree/ability/how many channels - of reception will best be discovered by You.
Install a ANT751 in the attic.
Test for reception of WYPX , ION , Qubo , ION Life.
Test for reception of the other low signal strength digital tv stations channels.
Test for reception with and with out a preamplifier in the attic.
Move the ANT751 to above the roof , test for reception with and with out the preamplifier.
If you will like to install a antenna Above the Peak of the Roof and dispense with the HD7082P big antenna and the testing with the ANT751 antenna.
Then as a Test.
Above the Peak of the Roof install a Winegard HD7000R All Channel Antenna aimed at about 280 degree magnetic compass direction.
Try reception with and without the preamplifier.
__________________________________________________
You can install the ANT751 or any other type or kind of antenna.
Here is the Truth.
There are No Honest Magic Tv antennas.
There are No Scam Magic Tv antenna.
There are No Magic Tv antennas.
Reason: Deleting off-topic content
