Old 20-Apr-2013, 3:10 PM   #1
Jake
Need Help - Wanna cut the cable!!
Hi Guys,
Thanks for all the good advice you give everyone on this forum! I’ve been reading for quite a while and have decided to see how the TV reception would be with an antenna before I cut the cable.
Here is my report… http://www.tvfool.com/?option=com_wr...1ddaf1b3703fdb
-This will be an attic installation (A-framed roof), probably 22 feet off the ground. Asphalt shingles.
-The coax will need to be about a 40 foot run down to the basement. Currently there is a 4 port RCA amplified splitter which feeds 4 tv’s.
I’m wondering if I can get a recommendation on an HD antenna for local channels, any splitter / amplifier, and even what gauge or brand coax to use.
Thanks in advance!!
Jake is offline   Reply With Quote
