Old 20-Apr-2013, 8:55 AM   #9
Marian
Here is the TV Fool report for 24' above normal terrain level: http://www.tvfool.com/?option=com_wr...1ddab3ebb12069
My concern about a pole so high (25' above the normal steep terrain), is how on earth we would mount the antenna, maintain it, and deal with getting it pointed, etc. I was relieved to see that the lower antenna height seemed to show better lines on the map (it was a surprise, actually). However, the lower antenna height is still significantly higher than what we have now. So I'll be interested to hear what you have to say about the report above. I was only looking at the map, as I didn't really understand the report details. The solid green LOS to the east at 84 degrees gives me hope. If we are able to pick up those channels, which I think are Fox and NBC, we will be satisfied.
On the Emerson TV, I've been selecting "antenna" all along in the setup mode, so the lack of reception is for another reason.
Marian
Marian is offline   Reply With Quote
