Old 19-Apr-2013, 6:07 AM   #2
Your location has (some but not all) Easy To Receive , OTA=Over The Air , Digital Broadcast Tv stations/channels of 2 directions.
Not all Tv stations are of 1 direction. That is why the Tv stations are of different directions.
One reason is , cities that are closer together can have their own separate Tv stations.
And cities that are far apart can have their own Tv stations.
Another reason is , many Tv stations have more then one transmitter location so as to cover/transmit over a larger and larger area.
Another reason is , Tv stations buy or lease land to install a transmitting tower , the land price , lease price , zoning regulations , are factors of where the Tv transmitting tower is.
Another reason is Tv stations on the same channel are further apart so as not to have same channel interference reception situations.
___________________________________________________
Attics and the inside of buildings Is/Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Signals are , deflected off the building , multi-path/reflection-signals bouncing all around in the attic and building , and signals are absorbed by building construction.
That said.
The reception of the Strong Signal Strength Local Tv stations/channels of 2 directions , about 262 and 54 degree magnetic compass directions are Strong at your location.
Instal in the attic , a Winegard HD7082P all channel antenna aimed at about 280 degree magnetic compass direction.
As always the starting antenna aim direction is the -> starting antenna aim direction.
Most Digital Tv's have a signal strength meter and some Digital Tv's also have a signal quality meter.
The current Tv channel bands are.
UHF band channels 14 thru 51.
Your location has receivable Tv stations/channels in all three Tv bands.
Instal the HD7082P all channel antenna that receives All 3 Tv bands.
WNYT , NBC , REAL UHF Digital channel 18 , at 54 degree magnetic compass direction.
And WNYT , NBC , REAL VHF Digital channel 12 , at 262 degree magnetic compass direction.
Are both , WNYT , NBC , with 2 separate transmitters at 2 locations.
WNGN-LP REAL UHF Digital channel 23 , and WNGX-LD REAL UHF Digital channel 25 , at 54 degree magnetic compass direction are both , FamilyNet - Religion.
The transmitting antennas are aimed in different directions , the transmitter is only 6.7 miles from your location so both signals are strong and will be received.
The Digital Broadcast Tv stations/channels that are in the Green and Yellow , Current Plus Pending Applications Included reception zones should be received.
If there are reception issues/problems that are not be resolvable by antenna aim adjustments and/or antenna location in the attic then Move the antenna to Above the Peak of the Roof for better reception.
WYPX-DT REAL UHF Digital channel 50 , virtual number (55.1) ION. Is Very Weak Signal Strength at your location and will most likely not be received with antenna in the attic.
If you will like to receive WYPX , ION , then install the HD7082P antenna above the peak of the roof.
Install a Winegard HDP-269 preamp.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
The HD7082P antenna has been discontinued , Amazon has 10 left in stock , http://www.amazon.com.
___________________________________________________________________
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path/reflecting , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or , 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
