Old 18-Apr-2013, 11:35 PM   #5
Aircraft flying through the path between you and the TV transmitter can cause the signal to break-up.
You can disconnect the cable TV signal from the coax in your home. Then you can connect OTA signals with no risk of 'broadcasting' the cable company signal around your neighborhood. If you are going to keep cable internet service, the coax cable serving your internet modem can not be used for OTA.
http://forum.tvfool.com/showthread.php?t=7293
http://forum.tvfool.com/showthread.php?t=13090
http://forum.tvfool.com/showthread.php?t=13034
