Thanks for the help.
The garage is already wired with the cable when I built it. I had cable tv running out there before. Would I be able to just tap into the existing cable system with the antenna and run it through the house and garage that way?
I should be above all the trees at 25 or 30 ft. I can always go higher if I need to. I do live about 2 miles straight south of the airport. Would that cause any interference?
Thanks again for your help. This stuff just confuses me.
