Old 17-Apr-2013, 10:48 PM   #7
Ok , the head engineer , Rick , WBIN/WYCN , says the the 3 transmitters , WORK , W04DP , W07DR , are located at transmitting tower in Derry.
The transmitters are Very Low Power and will not be received at your location.
There was some plans to put the transmitters on the south peak of Uncanoonuc
mountain for much larger signal coverage area.
Those plans have been scaled back and on hold with no current plans to put transmitters on Uncanoonuc.
http://en.wikipedia.org/wiki/WBIN-TV.
_____________________________________
For reception of.
WPXG-DT REAL UHF Digital channel 33 , virtual number (21.1-2-3) ION and Qubo and ION Life.
WENH-TV REAL VHF Digital channel 11 , virtual number (11.1-2-3) PBS channels.
WMTW-DT REAL VHF Digital channel 08 , virtual number (08.1) ABC.
WCSH-DT REAL UHF Digital channel 44 , virtual number (06.1) NBC.
The antenna can be 25 feet or higher.
___________
And to possibly reliably receive the Very Weak Signal Strength WGME-DT REAL Digital UHF channel 38 , virtual number (13.1) CBS.
The antenna will most likely need to be at 40 feet or higher above ground.
For reception at , 25 feet and higher , 40 feet and higher , antenna height above ground.
Install a Winegard HD7082P antenna aimed at about 60 degree magnetic compass direction.
And install a Winegard HDP-269 preamp.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
_____________________________________________________________
For reception of.
WMUR-TV REAL VHF Digital channel 09 , virtual number (09.1-2) ABC and Me-Tv.
WNEU-DT REAL UHF Digital channel 34 , virtual number (60.1) Telemundo.
Install a Winegard HD7696P antenna aimed at about 202 degree magnetic compass direction.
Install a Winegard HDP-269 preamp.
The 2 antennas and antenna systems are Separate antenna systems.
The 2 antennas and antenna systems Are Not connected together on to 1 coax.
The 2 Separate antenna systems are separate All the way to the Tv/s location/s.
At each Tv location a Remote control A/B antenna switch , switches from one antenna system to the other antenna system.
http://www.mcmelectronics.com. #32-4425.
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path/reflecting , blocking , OTA=Over The Air , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
