Old 17-Apr-2013, 4:51 PM   #5
Well Ok then.
No low band channels.
Hurricane/Gale winds. So install antenna lower.
And require a smaller structurally stronger antenna.
The Tv signal strengths are Strong at your location , the following antennas will work Ok.
Yes the , Antenna Craft / Radio Shack , HBU-33 or HBU-22 or HBU-11.
http://www.antennacraft.net.
Winegard HD7694P.
Or even a Antennas Direct C5 , the C5 receives VHF high band and UHF band channels and is a Very Strong and Sturdy antenna.
http://www.antennasdirect.com.
Remove and discard any coax connections weather boots.
To keep water out of outside , coax , connections , use the coax that has the Compression type connectors on the ends of the coax , not the Old crimp type connectors.
For outside coax ~ connections even the matching transformer (balun).
Wrap with , http://www.coaxseal.com.
Or.
At , http://www.amazon.com , scotch 2228 mastic tape 1 inch buy 10 feet.
_________________________
http://www.solidsignal.com.
http://www.amazon.com.
