Thanks for the reply. I really appreciate the list of stations that I should be getting so I know to keep troubleshooting. The preamp is completely disconnected and off the mast and the power unit is disconnected. I did run a cable straight over the roof to the TV but it was not new. The one I laid under the house was new though. I will get a new test cable. The "box thing" that I was talking about is the box that is connected directly to the antenna that the phasing lines go through.
<<<<<<As a Test to prove reception , disconnect the preamp (box thing) unit at the antenna , disconnect the power injector that supplies power to the preamp unit at the antenna , disconnect the power supply that is connected to the power injector that supplies power to the preamp unit at the antenna.
At your location , a minimum of these Tv stations should be received without an amplifier.
K18EL-D
KOPB-TV , PBS.
KGW , NBC.
KPXG-TV , ION.
KPDX-DT , MyNetwork.
KRCW-TV , CW.
KOIN-DT , CBS.
KATU-DT , ABC.[/QUOTE]
