					Originally Posted by  teleview
 It sounds like we have significantly different approaches to this type of testing. I don't want to read more into your use of the word 'loooong', but it seems that that term would very likely encourage adding loss to the test setup which would obscure the results... That is, if a signal was not received reliably during the test, one would be left questioning if it was a level problem caused by the added cable attenuation or antenna performance. If I'm not reading this correctly my apologies.
