Water in places it should not be tops my list things to look for. Often, it's easier to simply swap out a section of coax with a new or proven good piece... As you take things apart, be on the lookout for either moisture or corrosion in connectors. Water in coax causes unpredictable and variable effects. It's very common to see only one or a few channels affected and then intermittently.
Reason: sp.
