Old 15-Apr-2013, 7:07 PM   #2
A ->Simple<- Reception Situation.
Many , many , many , many , many , many , ATSC - Digital Broadcast Tv stations/channels will be received.
The current Tv stations channels transmitted are.
UHF band channels 14 thru 51.
Your location has Receivable Tv stations channels in All 3 Tv channel bands.
Recommend install a All Channel Antenna.
Install a Winegard HD7000R , All Channel Antenna , aimed at about 310 degree magnetic compass direction.
I Strongly recommend install the antenna UP HIGH.
Here is a antenna mount that installs on the eave of the house , http://www.ronard.com/34424560.html. use the #4560 eave antenna mount.
Here is a chimney antenna mount , http://www.ronard.com/ychim.html.
Buy the ronard antenna mount at solidsignal buy typing the word ronard in the solidsignal search box or buy from ronard.
Here is a , J pole type antenna mount. Winegard DS3000. UP HIGH on the eave.
Or relocate the dish antenna mount UP HIGH on the eave.
______________________
The ATSC - Digital Broadcast Tv Reception is Strong Signal Strength at your location.
___________________
Do Not use any type or kind of antenna system amplifier.
___________________
For 3 Tv's connected use a simple common 3 way splitter.
For 4 tv's connected use a simple common 4 way splitter.
___________________
http://www.solidsignal.com.
http://www.amazon.com.
___________________
As always <- , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path/reflecting , blocking , OTA=Over The Air , ATSC - Digital Broadcast Tv Reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including you own roof and house.
___________________
The Tv/s Must Channel Scan for the ATSC - Digital Broadcast Tv stations/channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv Transmissions travel through the Air from the transmittinmg antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
___________________
Some satellite systems will except a broadcast Tv antenna connected to the system and distribute the antenna reception to the Tv's , and some satellite systems Will Not.
If you have discontinued satellite Tv service.
Then to ->Avoid<- reception and distribution problems , Disconnect and Remove ALL satellite distribution hardware , multi-swithches , multi-plexers , special couplers , amplifiers , power injectors , power supplies , and etc. .
Yes you can use the coaxes that are in or on the house for the Broadcast Tv antenna system.
