The situation that comes to mind is , damaged coax / connectors.
Disconnect the coax from the splitter that feeds the Tv with the problems.
Connect a New long coax to the splitter and run the New long coax to the Tv that has the reception situations.
And ->All So , any and all other , coax , couplers , connectors , splitters , electric , electronic devices and etc. , can be the cause of odd and strange reception situations.
And also , having the antenna in the attic can also be the cause all manner of odd and strange reception situations.
The idea is to install a Tv antenna at location that has the least amount to no amount of - any thing - that can effect reception in a negative way.
______________________
I remember a situation that , at a house I was was checking out reception problems of cable Tv.
I finally solved the reception problems.
I replaced 3 coax jumpers that connected VCR's and cable boxes to the 2 Tv's.
Looking at the coax jumpers , the coax jumpers , looked 100% , no visable damage.
2 coax jumpers had broken center wire and the 3rd had damaged separated foil shield and shied wires.
This story is to provided to help expand the thinking , not limit the the thinking to only coax jumpers.
Reason: Clarify information and typos.
