I know no such thing: and I have desire to invade the poster's privacy, either. As for what the poster needs, he needs a deep-fringe antenna system mounted on his roof, and here is the recipe for success:
An AntennasDirect XG-91 UHF antenna
A Winegard YA-1713 or AntennaCraft Y-10-7-13 VHF high-band antenna
A Channel Master Titan 7777 dual input preamplifier
Install the system on a single mast, with the UHF antenna on top of the VHF antenna, separated by at least 4' vertically on the mast. Connect the output of each antenna to the correct input on the preamplifier, then run the output of the preamp to it's power supply, which must be mounted indoors. If desired, you can add a passive splitter after the preamp power supply, which will allow you to power 4 or more TV sets from the same antenna system. Be sure to aim the antennas at 307 degrees, as measured by your compass. You WILL see all the major LA stations when you complete the installation.
