A Google search says that 1.25" EMT should have a wall thickness of .065" which should be around 16 gauge.
http://www.westerntube.com/electrica...lic_tubing.htm If you need something heavier , there's also 1.25" IMT (.095 nominal wall thickness) or 1.25" RSC (.133"), both of which are approx 1.5" to 1.7" in OD.
FYI, ALL of our outdoor antennas feature mast clamps that can accept up to a 2" OD mast.
Updating this as our new DB8e is an exception. It will fit up to a 1.75" OD mast, a change necessitated by the mounting hardware scheme and the combiner box that was used.
