Old 12-Apr-2013, 12:20 AM   #8
herb
Can you consider using a vent pipe mounting kit? http://www.3starinc.com/ez70_vent_pi...a_bracket.html This type of hardware is not appropriate for use on PVC or ABS pipe.
Eve and wall mounts are also worth considering. http://www.3starinc.com/antenna_mounts_and_masts.html
Hi GUM,
Unfortunately, all our pipes are PVC However, wall or eve mounts look WAY better than "how'm I gonna get thru that concrete tile." Thanks!
Do you think that's an option if I need to get the antenna above the neighbors' houses? Could have to be several dozen feet high...
herb is offline   Reply With Quote
