Old 12-Apr-2013, 12:17 AM   #7
herb
Can you mount a small antenna on the dormer above the garage? It could be either inside or outside. An ANT-751 might do the trick.
ThanksTower Guy,
That ANT-751 looks very promising; I like the way it mounts. Do you think that it will be able to "see" around the neighboring houses adequately?
herb is offline   Reply With Quote
