You're doing fine... Your latest TV Fool report is free of obvious warnings that would cause us to wonder if it's accurate.
To confirm, based on the coordinates shown, your location is about 50 miles east of Winnipeg, near the junctions of route 15 & 11. If this is accurate, the signals available to you are very weak. Only the very largest antennas will give you a chance at reception.
Can you consider the construction of a tower? If you have a tall building available, how high is the roof peak? Added height may provide access to more signal strength.
