Did you use the mast pipe section and sections and the ANT751 and walk around your property - probing lower to the ground and higher above the ground - for the best reception??
Is there a house in the direction of the transmitters on South Mountain that is higher/taller then your house and is blocking reception??
If so , can you probe for reception at locations on your property that provide a better ~~view , of South Mountain transmitters.
