Go to the tvfool home page and click on >>Start MAPS<<.
Put in some address or zip code that is around your area or some where else.
When you get the map , Move the pointer to your Exact location , move the pointer to the place you have receiving antenna.
25 feet antenna height is a reference starting antenna height that provides a good idea of reception.
If your antenna is higher then 25 feet then use that antenna height.
Click on , Make Radar Map , button.
Copy the information in the address box/line at the top of the computer screen , on to a paper.
As a reference to know what the address box is , The address box starts like this , http://
At your post here at tvfool at the top of this 'box' is a blue circle with a chain link.
Click on the blue circle with the chain link.
In that box/line copy the information that you copied from the address box/line at the top of the computer screen.
