Old 10-Apr-2013, 9:50 PM   #3
Skip any and all amplifiers in this location at this location - they would only cause new troubles. You have plenty of available signal power. I'd probably also chuck that particular amp into the e-waste recycle bin. I tested one of them this week and couldn't believe they actually sell something that behaves the way this one did.
All you need is a small UHF-only antenna aimed at Farnsworth Peak and a 4-port splitter for the main SLC stations.
As far as the attic is concerned, be patient and be prepared to try different spots for the antenna. If you have a typical asphalt shingles over plywood roof on the home it should work well enough.
