Old 10-Apr-2013, 9:00 PM   #2
The amount of green in your TVFR is quite encouraging. Excellent reception should be quite easy to get.
The broken antenna can't be trusted to deliver an acceptable signal so it needs to be replaced. It would be good to know that the old antenna produced acceptable reception at one time though.
I'm reluctant to label any antenna as 'a good attic antenna'. I think more in terms of the attic being a less than ideal place for any antenna... some attics are OK... others are completely unacceptable. It has to do with the construction materials used to build the home. An attic may have been an acceptable location in the past, but an added layer of roofing material or new heating ducts may have rendered it unusable as an antenna mounting site.
But your signal conditions call for lots of optimism. You should not need a large antenna to receive plenty of signal power from the air. Any of the 2-bay panel antennas will perform well, even in an attic that has moderate signal attenuation.
Examples would be the Antennas Direct DB2e and CS2, the Channel Master CM-4220 or you could use the slightly larger 4-bay panel antennas such as the DB4e & CS4 from Antennas Direct, the U4000 from Antennacraft, the CM-4221 from Channel Master or the HD4400 from Winegard.
You will want to aim by 'facing' the antenna toward WSW (245° per a compass). The back of a panel antenna is a reflector screen and the mounting clamp.
Do you want to include reception of KUTF, a Spanish language station? If so, you'll want to add a second, somewhat specialized antenna. The Antennacraft Y5717 pointed toward NNW (340° compass). You would also need a UHF/VHF signal combiner to correctly mix the two antennas into a single coax down-lead.
I'm not a huge fan of the RS amplifiers, but if you have it, you can try it. I would opt for a passive 4-way splitter and avoid the noise and distortion problems caused by the amplifier... you have plenty of signal power, especially if you use a 4-bay panel antenna.
