Old 10-Apr-2013, 4:32 PM   #8
The vhf antenna reccomendation from groundurmast is HUGE.
The hill that you're behind is even bigger. Not much signal is going to make it around that hill.
Your best bet for that stations is the large high-VHF antenna plus a VHF-only pre-amp one or more FM filters before the amp. You have local FM stations that are probably clobbering the weak channel 10 signal.
WBBG from Springfield has similarly impaired signal path due to terrain. You're probably going to need an amplified directional UHF antenna for that one as well as patience and persistence.
