Old 24-Oct-2010, 1:57 AM   #8
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
I'm sorry, but that's an absolute-trash recommendation. That antenna might be OK for a boat, but all your stations lie in one direction, less than 30 miles from you Use a directional antenna like a Winegard HD7694P or an AntennaCraft HBU-33 aimed at 120 degrees: it will work better at less than half the cost, has no moving parts or amplifiers, and is easy to install. Everything that you expect from Austin will come in perfectly when you do.
