You have a good chance at seeing some of the weaker signals if you mount high, using a high gain antenna such as the HD7698P.
Be sure to avoid preamplifiers that are not specifically intended for strong signal conditions. The two suggestions provided thus far can tolerate the strong local signal better than many other preamps.
