Old 8-Apr-2013, 11:15 PM   #5
A simple reception situation.
Above the Peak Of The Roof in such a manner that the roof and house are not blocking reception to the , east/north east , south/south west.
Install a Winegard HD7698P antenna aimed at about 50 degree magnetic compass direction.
____________________________________
Install a Winegard HDP-269 preamp.
For 1 tv connected use No splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
http://www.ronard.com/909911.html , use the 5 or 7 foot antenna mount.
http://www.ronard.com/34424560.html , use the #4560 eave antenna mount.
http://www.ronard.com.
_______________________________________
The HD7698P antenna can also be turned by hand to Test reception of the , south/south east Digital Tv stations/channels.
Aim the HD7698P antenna at about 192 degree magnetic compass direction.
Rescan fo Digital Broadcast Tv stations/channels.
____________
Tv antenna rotators Are Not channel surfing friendly , must wait for antenna to rotate and there Will Be Domestic Situations about the direction the antenna is aimed.
___________
If You Will like to receive the Digital Tv stations channels of both directions.
The install 2 SEPARATE Antenna Systems.
Both antenna systems will be the same setup as described above.
The 2 SEPARATE antenna systems Will Not be connected to each other.
The 2 SEPARATE antenna systems are Separate all the way to the Tv locations.
At each Tv location will be a Remote control A/B antenna switch.
http://www.mcmelectronics.com , #32-4425.
A/B antenna switching Is Channel Surfing Friendly , press the button on the Hand Held Remote Control , change antennas and Keep On Channel Surfing.
If install ing 2 Separate antenna system , separate the 2 HD7698P antennas by about 3 feet on the same mast.
As always , trees and tree leaves , plants and plant leaves , do a good job of , absorbing , multi-path/reflecting , blocking , Digital Broadcast Tv reception , and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7698P antenna at a location that has the least smount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup M<enu and select , 'Air Channels' / 'Antenna Channels'.
